1 - 20 of 49 Posts
Can someone send me a link to some good quality HIDs for a reasonable price. I know some cheap HIDs that start to flicker or one bulb is dimmer than the other, I hate that! lol.
Got a 05 G6. I belive the bulb type is H11 for the low beams and H9 for the high beams... I think.
I see a lot of users on the sites that use DDMTuning HID Kits.
http://ddmtuning.com/Product-Categories/HID-Kits-Lighting/HID-Kits
It's $30 for a kit and from what I can gather a lot of people really like it.
I got my kit from ZZPerformance, it works but i paid a bit more money for it.
I did the LOs but i left the HIs as Halogen. Simply because I use my brights a lot and i'm told you shouldn't turn HID lights on and off frequently. It's bad for the ballasts.
@CruisinG6: Thanks for the link. I'm going to get them from ZZPerformance. And also where did you get your rims from? I love them. Also do you have a 35W or 55W kit?
I got a 35w kit, If you look here
You'll see the difference the watts make. Also the 55w bulb will work hotter then a 35w
And yea ZZP sells them as a fog light kit for the cobalt. the H11s at least.
My rims are actually the stock steel rims. I took off the hubcaps and got some new closed-end lug nuts, Painted the rims black and added a red strip in the inside of the lip. So it's not seen all the way around the wheel.
Also if your interested I found on amazon and eBay projector lenses for the G6 so the HIDs will work as they should. Thing is I personally don't like em. haha
Here's a close-up of the wheel
I'm thinking about painting mine all black. I like the wheel pattern so i'll probably stick with them for a while. I saw the chart and i'm going with the 35W 6K kit, I was confused for a bit when i went on the ZZP website cuz i did see them for the Cobalt fogs, but they are H11 and for the Hi beams i'm going halogen as well. Do you have a kit for your fogs? and what type of paint, coats and or primer did you use for your wheels? Very clean.
These are the wheels my G6 has.
http://www.finishlinewheels.com/prodimg/ALY06582U.jpg
Not sure if I'm too late with this post, but I just installed my HID kit today and so far I'm very happy with them (knock on wood). I bought a Xentec HID conversion kit off ebay, it was around 33$ with free shipping. I got the 10000k kit but they offer all the different temps as CruisinG6 posted. I haven't experienced any problems with flickering or brightness yet. They're very bright and exactly the color I was looking for. I left my HI's as halogen as well. I'm sure the ones you were thinking about are fine too, just posting my input!
I don't have factory fog lights, I got an aftermarket kit from walmart that required some modifications like 3 times. haha
Long story short they're just basic flood light bulbs that i put yellow lamin-x over
As for my wheels because they are steel I had to scuff them up, Then a layer of etching primer, Then some light layers of paint until it was even and full. I used all spray paint. I'm pretty sure your wheels are aluminum, but you can still paint them. But I think it has a coat of clear coat over it already. I have a friend who does rim/wheel repair, he may be able to help you out.
I just think you'll need to strip off the clear coat and scuff it up and then you can prime and paint.
Discussion Starter #8
@cswild26: Yea i've purchased the same brand before, for my Civic's that i've owned and other cars i've had as well and they all went bad on me, either they started to flicker, or one bulb will go in & out. I remember once i bought a kit for my EK hatch and the wires burnt!! as soon as i turned my lights on, Note that ive installed HIDs the right way, I've own 16 Hondas/Acuras, so i know my stuff pretty well when it comes to imports. But i don't wanna touch ebay crap anymore. Maybe it depends the type of bulb your using and if it's made the right way, that's just a guess tho.
@CruisinG6: Thank's a lot for all this help, i really appreciate it bro. What will i need to scuff them up and take the clear coat off of them. I've never done rim work to any of my cars ive always bought aftermarket performance wheels w/ tires. I really want to keep this G6 clean, i really like it for a DD. I'm going to post pics of my 2012 Si sedan and G6 later after i get out of work. If your friend can help me that'll be awesome!
Well to strip and scuff the wheel you can use an abrasive pad, or disc on an air tool, basically go all around and get the whole surface done. Then you'll sand it with some 200 grit I think, and then you can paint. I haven't done aluminum wheels myself but heres a how-to link i found
http://www.ehow.com/how_4914001_paint-aluminum-wheels.html
But Personally I wouldn't tackle it myself just because I haven't done those kinds of wheels myself. prep is key they say.
If you want to try my buddy here's his website, http://www.lakecountywheelrepair.com/ I'm sure he'll hook you up and do a good a job. He's the one who did my wheels. but I helped where I could :D
Thats dissapointing, hopefully i didnt waste my money on the wrong kit then. Day 2 has went by with no problems, not that a lot normally goes wrong within the first two days though. Ill keep you guys posted on how they play out in the long run, others might be interested to see if they end up working out. Thanks for the heads up man, gives me something to be looking out for.
You may luck out and get a good kit, I don't know how familiar you are with HIDs, but a blown bulb will turn Pinkish, and a blown ballast will leave that bulb simply not working
I've been curious about those DDMTuning kits that I see a lot of people have. $30 seems like a great price, but I wonder about quality
Discussion Starter #12
cswild26: Yea keep us posted on how they turn out. If you get lucky im gonna be sooo mad hahahaha!!!
CruisinG6: Maybe i should buy mine off DDMT Tuning and keep you guys posted on how they are.
I had a DDM kit in my GTO for 4 years without an issue. I have a DDM kit in the G6 now and I'm going to buy another kit for the fogs here on Friday.
I would like to know, because my ZZP kit is starting to have a problem. First problems out of the kit, the light seems to "bounce" You can't see it by looking at the light, but you can see it in the light pattern on the ground. It's odd, seems like the arc is moving around the bulb too much or something. But it could be normal and just noticeable because I don't have projector headlights.
Those bulbs u found are just simple replacement bulbs with the blue tint, Although it says HID. it's not the true HID for it has no ballast and doesn't require one. This is like the cheaper alternative to achieve the blue bulb look
Those fake HID bulbs are not the best from my past experiance. I put them on my tiburon when I was 16 and didnt know any better and they have terrible light output. Driving at night was horrible. They looked ok at night time but not nearly as bright or good looking as the real thing.
From what I've read the Higher you go in color/temp. for example. 8000k 10,000k 12,000k the less light output there is. So the lower in temp, the more yellowish in color, the more light it produces
Discussion Starter #19
@CruisinG6: That is true, 6K is the way to go. Gives you a nice look and their bright & clear. My buddy has a 55w 6k kit on his 8th gen SI and it looks good. Kinda how the new Audis and BMWs have their stock hids, its clear and bright plus super clean look. And they have a very small tint of blue you can barely tell tho.
Yhup 6k is the way to go lol I got DDM'S 35 watt 6k's, high and lows and they work greattt. The funny thing is they sent 4 H11 bulbs, which i believe are the high beam bulb? But they all work wonderful.
1 - 20 of 49 Posts
