1 - 13 of 13 Posts
I've found that many people have asked about it, but nobody has gotten an answer. During moderate to hard acceleration there is a very loud squeal coming from my engine compartment - belt was replaced recently and its still there. It seemed to be reduced for about an hour after I got my car back then returned right back to being as loud as ever.
Some people have cited the tensioner or some sort of PVC leak causing the noise, and I just want to see if anyone out there has any clue the source of this noise. Pretty disappointing because this is a great car otherwise.
· Moderator Member Thingy
I have a similar noise too, but I just keep my audio up to drown it out. It doesn't take much to overpower it.
Ahh I've had this noise for 25k miles and through one belt change now, not only is it annoying but it's quite frankly BS that so many people have had this problem and GM hasn't identified it. Because of the rev limiter you also can't hear the noise unless the car is in gear, further complicating being able to show it to a technician.
Agreed
I am right there with you. I have had the noise for quite some time. Took it to the dealer where it was purchased, looked under hood, drove it, lifted it up and accelerated in park.... couldn't find anything in the engine or exhaust that they could pinpoint to be the source of the squeal. Mine is just like everyone else's, only happens when I accelerate rapidly or get above 2500 RPM slowly. REALLY bugs me and I would LOVE to hear the pur the car would have without it.
· Banned
Replace your serpentine belt. Its real easy to do. I had the exact same problem, and when I got a new belt on, it went away. So def give that a shot.
**Keep in mind that I also have the WAMS tuned pcm so my shifts are smoother than stock**
Not always the belt though. Mine is a new belt but I think the tensioner thing is the problem. I need to tighten it, but hey I got to do a lot of things in life. I convinced the last person in my car that it was the turbo. Seriously they believed me lol!
It does remind me of a turbo whistle and could be mistaken as one for sure.
I Agree!
I have this problem too with my 2008 Pontiac G6 Convertable and it's driving me nuts!!!:mad:
It was happening on a regular basis - But now, it is on and off - I read some of the other posts and they all sound like mine - I hope that it can be fixed.
i'm prety sure Jetmech had the same problem and found he had a small hole in his flex pipe and he fixed it. Maybe he'll see this post and chime in. I'll see if I could find his post.
First off, hi, just joined the site tonight. I’ve had my 07 convertible for 2 weeks, purchased as certified used, 34,000 miles. I have mine in the shop right now for this same problem. Service guy says it’s the exhaust, something related to a small hole he said that causes a whistle. He also told me that he’s got a service bulletin from GM acknowledging it but it says not to fix it. I’m in the process of going through the service manager and then I’ll go to the owner if necessary. I knew the car had this squeal when I test drove it, mentioned it to them and they said no problem they would fix it when I brought the car back for a seat belt guide that was broken. I’ll get to the bottom of it one way or another or I’ll tell them to take the car back. There is absolutely no way I or anyone else in my opinion would buy a car knowing it had this squeal and could not be fixed. I think I remember reading on Edmunds that other have had to have the exhaust changed by the dealer to fix it.
Art.
Has anyone solved or identified this issue yet? Our 2008 G6 convertible squeals from 2000 to 2300 rpm and then stops. Sure I can turn the music louder or baby the acceleration but they don't fix the problem. Any help w/b appreciated.
Mine was definitely the exhaust. After some arguing with the dealer and threatening to return the car because it was written down when I purchased the car that the “squeal” had to be fixed, they replaced the exhaust. I read the GM tech bulletin and it’s complete BS, says the weep hole is functioning as designed and the exhaust should not be replaced. Many early G6 owners said that replacing the exhaust fixed the problem but that it reoccurred within 8K-10K miles. I’m currently at 12,000 miles on the new exhaust and still no whistle. Maybe they replaced it with an after market exhaust that either has no weep hole or it’s in a different place on the pipe.
Had they not replaced the exhaust I wasn’t actually going to return the car. Some said they welded or pop riveted the weep hole but then you lose the ability of the exhaust to drain condensation and it rots from the inside out. If the weep hole is the culprit then I personally think you could tune it out or at least change the tone. I personally believe the exhaust flowing across the hole acts the way sound is produced in a flute. I think either changing the size of the hole slightly (bigger or smaller) or the angle the exhaust hits the hole would change the tone or eliminate the sound all together. I was going to try this myself if they were not going to swap out the exhaust. I think if you were to put a strong pick or pinch into the hole and bend it to one side should change the angle the exhaust flows across the hole and change the tone. You may need to tap with a punch on either side of the weep hole if you can’t actually bend the metal. Another thought is to screw a small slide hammer into the hole and pull it out a little creating a dimple in the pipe. I don’t know if you should have the exhaust hit the hole head on or from the backside, you’d have to experiment. Personally I would try head-on first so the exhasut flows out of the hole instead of over it. I climb a 6% 2 mile-long grade on my way to work and that sound drove me nuts, people in the car next to me would stare because of the noise.
If someone tries my idea and it works please let me know. I’m crossing my fingers that my whistle doesn’t return.
Art.
1 - 13 of 13 Posts
