I wasn't so lucky with the ball popping out of the sockets, so after about ten minutes of prying and cracking the top plastic mounting bracket with no luck, I pulled the lower corner of the headlight outside of the facia (placed a rag between the facia and assembly) and was able to reach my hands in there to get to the bulb, replaced both in about ten minutes or less after that. Only bad thing about this is that you can access the low and high beam bulbs this way but the marker lights are still in a tight spot... hope mine don't go out any time soon?
Question? Anyone experience problems with their high beams not working on auto after replacing the bulbs? I kind of think mine goes beyond the bulb problem, when I went to pull out the first bulb (hot as """" by the way) it came on as I was twisting it off? I know, I should have had the lights off as I was replacing them but with the one burned out (so I thought) the other wasn't working so I assumed they were off but they weren't. Once I got it all together the high beams didn't work when on auto but they worked when you put the switch to the manual setting. Any clues... short somewhere maybe? BTW, I had noticed that the high beams didn't work on auto before changing the bulbs but they did prior to this. Hmmm wonder if my daughter could have done something to mess them up... she just started driving two weeks ago and she was the driver when all this came about???
