i've got a 2006 g6 that an ex girlfriend and a knife went to town on lol needless to say im needing to change my gauge cluster out what all do i need to remove to be able to remove it?
A couple scews in the top, it pops off around the wheel, that removes the surround. A couple maybe 7mm bolts then pull it out and unplug it. But my memory is crap. I removed mine to put on white face gauges.
Sent from AutoGuide.com App
ok ya i got a new cluster coming with the white face already in it i just dont want to be crackin the dash and shit to try and get it out
You shouldn't crack the dash. Once you pull the plastic cowl off that goes around all the gauges (2 screws on the top) you'll see exactly what other screws have to come out. Once they're removed you should be able to just pull the whole cluster towards you and then out.
I recommend pulling your steering wheel as far down and away from the dash as possible to give you more room.
ok cool once i get the new cluster in im going to attempt it so if i have any questions along the way ill post up thru here any ideas where to get decent prices on seats and headliner cause the headliner has a smiley face in it and my seats had all the fabric cut out
also have to replace air vents, mirror and visors
damn, what a bitch of an ex...
If the cluster is anything like my oldsmobile was (which is probably the case) you'll probably remove that plastic cover, look at it, and then have it done in like 10 minutes. haha
How torn up is the headliner? Is it just the fabric, or is the entire board underneath toast as well? You can get some headliner material and glue it on, if you need a new board you can probably use the old one as a template and make a new one. Or maybe you can find one somewhere.
How bad are the seats? My guess is the padding is destroyed as well the fabric. You may be able to even repair that yourself, but I'm sure it won't be the same.
I think your best bet, cost wise, is to just get it all from another G6. Maybe check out salvage yards or craigslist for a totaled G6. If someone rear ended the hell out of a truck or something the interior could be in perfect shape.
Or you could go the newish route, ebay for instance is always good. You can check out GMPartsDirect. You can get GM parts at warehouse prices, it can also provide some diagrams to show how things go together, problem is it doesn't really give any part numbers.
