I have a 2008 G6 Convertible and the corner of the rear bumper got pushed in... I do not see any damage to the actual bumper so I just want to push back out the plastic cover but can't get enough leverage behind it to get it all pushed out. I thought if I could either loosen it or remove it, it would be easier to return it to the original shape.
Thanks in advance!
Should be pretty straightforward. Two bolts near the trunk and then remove all the fender pins.
http://www.g6ownersclub.com/forum/attachment.php?attachmentid=2706&stc=1&d=1327205048
Fascia Screw (Qty: 6)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
10 N·m (89 lb in)
Fascia Bolt (Qty: 2)
Tighten
10 N·m (89 lb in)
Fascia Bolt (Qty: 4)
Tip
Pull back rear compartment carpet to gain access to bolts.
Tighten
10 N·m (89 lb in)
4
Fascia Retainer (Qty: 5)
Tip
• Use a small plastic wedge to release the retainers.
• Pull on fascia upper center to release the retainers.
In some cases it would help to use a heat gun to soften the plastic to push the dent out, if one is not available you can try using a hair dryer.
