I just noticed the clunky sound in my steering wheel, and I'm having a local mechanic look at my steering rack, and suspension for any other issues.
I understand that replacing the I shaft fixes the problem, but for how long? I don't think I have heard of anyone with a permanent fix for this, so is it worth putting any money into the issue?
Of the many things to go wrong with the steering, is this all related to the EPS system, and are these signs to indicate that my steering will lock up?
I need to know these things soon, becuse if this is truly a lost cause, I'll be trading my 06 G6 GT coupe on something else very soon.
I really wanted to hold on to this car, but if GM can't own up to their mistakes, than so be it.
I don't think you need to replace the steering shaft. The fix for it is just to grease it. There is a tool out there for this and it solves the problem but not indefinitely. If you have electronic steering I don't think you will have this problem. The electronic steering is the only one that tends to have lock up issues.
As for being a lost cause...well it depends on what your definition is. At 100K miles and your car needs suspension work is not abnormal. You could trade your 6 in on a Toyota...I'm just sayin'
Um, don't quite understand this statement.
Steering wheel lock up issues that the Pontiac G6 is having is related to electronic steering models only.
The clunking sound is related to Pontiac G6 models that do not have electronic steering. The shaft that goes to the the steering rack causes the clunking noise and can be remedied by greasing the space between the inner and outer shaft.
Make sense?
Discussion Starter · #5 ·
Make sense?
Yeah, except that my car has the clunking issue AND it has the EPS.
It really sucks that GM won't address the issue with the G6, I really want to keep this car :(
Here is the service bulletin on your problem. Print this out and take it to the dealer.
I though that the EPS did not have the clunking issue but I was wrong, sorry.
So I looked up some info on it.
It had pictures with it but I could not get them to post here. If you want to PM me and send me your email addy I will send them to you.
TECHNICAL
Bulletin No.: 06-02-32-007F
Date: August 24, 2009
Subject: Clunk, Knock or Rattle Noise From Front of Vehicle While Driving or Turning Over Bumps at Low Speeds (Diagnose Noise and Perform Outlined Repair)
Models:
2004-2006 Chevrolet Malibu Maxx
2004-2008 Chevrolet Malibu Classic
2008-2010 Chevrolet Malibu
2005-2010 Pontiac G6
2007-2010 Saturn Aura
Supercede:
This bulletin is being revised to update the models years and revise the information for Correction 2. Please discard Corporate Bulletin Number 06-02-32-007E (Section 02 - Steering).
Condition 1
Some customers may comment on a clunk noise heard and felt in the steering wheel while driving at slow speeds and turning. The clunk noise may appear to be directly in front of the driver. Hitting a bump while turning can produce the clunk noise. Sometimes the noise may be duplicated when the vehicle is sitting still and the steering wheel is turned 90 degrees in either direction before initially centering the steering wheel.
Cause 1
The clunk noise may be caused by a slip/stick condition between the inner and outer components of the intermediate shaft.
Important
Revised design intermediate shafts went into production in the 2009 model year and are the only design currently available through GMSPO since approximately September 2008. Since any model year vehicle could have had a second design shaft installed, it is critical to identify it before proceeding. The revised design intermediate shafts will NOT tolerate any type of lubricant per the following instructions. Adding lube to the second design shafts will cause a clunk noise in a very short period of time. Use the following pictures to identify which design of shaft you are servicing.
Electric Assist Power Steering
First Design - Bare Steel Tube (Lube OK)
Second Design - Black Painted (DO NOT Lube)
Hydraulic Assist Power Steering
In the unlikely event that the source of the noise is identified as a second design shaft with black painted tube, it must be replaced.
Correction 1 (Only for First Design - DO NOT USE FOR 2ND DESIGN)
Lubricate the intermediate shaft with steering column shaft lubrication kit, P/N 26098237.
1. From inside the vehicle, remove the instrument panel insulator panel - left side panel to gain access to the intermediate shaft.
2. Remove the intermediate shaft to steering column attachment bolt.
3. Remove the intermediate shaft from the steering column.
4. Extend the intermediate shaft all the way. Using the intermediate shaft grease kit, P/N 26098237, inject the grease into the gap between the inner shaft and the outer shaft as you are collapsing the shaft. This will draw the grease into the shaft.
5. Cycle the shaft up and down several times to distribute the grease.
Important
Remove original thread locker material from the bolt and apply Loctite(R) 242 (or equivalent) to the threads of the bolt and reinstall intermediate shaft bolt.
6. Install the intermediate shaft to the column.
Tighten
- For electronic power steering, tighten the bolt to 49 Nm (36 lb ft).
- For hydraulic power steering, tighten the bolt to 62 Nm (46 lb ft).
7. Wipe off any excessive grease on the intermediate shaft to avoid damage from drips on the carpet.
8. Install the instrument panel insulator panel - left side.
9. Verify that the noise is no longer present.
Condition 2
There may be interference between the clamp and the steering gear input shaft. The clamp is beveled and if forced down on the input shaft too hard, it may cause a loose fit with the intermediate shaft to input shaft joint.
Correction 2
To correct this condition, perform the following steps:
1. Remove the intermediate shaft pinch bolt at the steering gear end.
2. Install a new bolt, GM P/N 26058124 (Chevrolet, Pontiac) or P/N 26046722 (Saturn), but do not tighten the bolt at this time.
3. Pry the clamp up using a pry bar to position the bolt into the upper part of the groove as shown above. This will position the clamp off the bevel.
4. While keeping the clamp in the upper position, tighten the bolt.
Tighten
Tighten the bolt to 49 Nm (36 lb ft).
5. Verify that the clunk noise is no longer present.
Condition 3
Important
This condition ONLY applies to 2004-2007 Chevrolet Malibu/Maxx and 2005-2007 Pontiac G6.
Some customers may comment on a knocking or rattling type noise from the front of the vehicle when driven at low speeds and over bumps. The noise only occurs when the steering wheel is in the straight ahead position and sounds like the noise is in the left suspension of the vehicle or directly in front of the driver.
Correction 3
1. Ensure the noise is not caused by Condition # 1.
2. Determine the source of the noise. Install the chassis ears at the following locations:
- sway bar link - one side at a time
- upper strut mount - one side at a time
- steering gear near the pinion area
- base of the steering column housing
- radiator surge tank
3. If the noise is coming from the upper strut mount or sway bar link, replace as necessary and retest.
4. For 2004-2006 Chevrolet and Pontiac model year vehicles, the noise may be coming from the radiator surge tank area. (The 2007 model year vehicles use a different style radiator surge tank - refer to Step 9.)
5. If the noise is coming from the radiator surge tank, release the two retaining tabs holding the radiator surge tank and reposition the tank away from the attaching bracket and isolate with closed cell foam.
6. Cut three pieces of closed cell foam, P/N P46515 (or equivalent), into 25 mm (1 in) by 102 mm (4 in) pieces.
7. Cut two pieces of closed cell foam into 25 mm (1 in) by 6 mm (1/4 in) pieces.
8. Install the three pieces of foam to the attaching bracket starting at the top center inside the bracket and proceed down across the fuel lines, then at the inside of the bracket at the left and right positions of the center piece of foam. Finally, install the last two pieces of foam to the inside bracket at the left and right extended sides behind the retaining holes as shown above.
9. Reposition the radiator surge tank back onto the bracket and seat the two retaining tabs on the tank.
10. Drive the vehicle to verify that the noise is no longer present.
Parts Information
Order Adhesive Back Shim Stock from Kent Automotive at 1-888-YES-KENT or onlhttp://www.alldatadiy.com/alldata
