1 - 9 of 9 Posts
Discussion Starter #8
Needs to be within 12" of the battery, because if you get a short the fuse protects your car from things like fire. Where it is, the wire could still short at the firewall and then there is no cut off from the battery.
ahhh... good to know haha... ill fix that asap
Also I've seen several amp fuses melt and burn up. You wouldn't want that to happen in the passenger compartment with it sitting right on the carpet. As mentioned closest to the battery as possible for maximum protection is your best option.
1 - 9 of 9 Posts
