Depends when you want it to be powered...
If you want it always on, look for a fuse that is always on (for example interior lights)
If you want it on only with ignition, you could use the power mirrors, or windows for example.
But before you start wiring, always use a multimeter to check the circuits are powered how you want (and check polarities), and use an Add-A-Circuit!!!!!!! Try to aviod splicing into wires.
