G6 GT member
I have a 2008 3.5L G6 GT Coupe (2 doors, big factory spoiler)
I think I need a new catalytic converter but there's a ton of different types! Left, right, direct and Manifold integrated!! Most websites say to make sure you know the pipe diameter also! HELP!!!!!
With the 3.5L V6 you're going to have 2 front and 1 rear catalytic converters.
Item 1 is the Front Right. Item 2 is the Front Left.
In that pic #2 hooks into #1 on that open port(with gasket #5 sealing them)
So if it is a front cat, you'll be looking for the terms Front Right or Front Left.
There is only 1 rear cat for your car.
And you do not have a manifold integrated...that is the 4 cylinder car.
If you search on Rockauto.com for the parts you'll see pictures of them and be able to compare those to what you see on your car.
G6 GT member
OMG!!! 3!!!! How do you figure out where the blockage is?? So many possibilities!! Does each catalytic converter have It's own code? It might not even be a catalytic converter issue!
So the "back pressure test" should be the initial test. What comes next in finding a solution? The garages in my area seem kinda clueless to fixing this issue without the car throwing a specific code.
G6 GT member
Discussion Starter · #4 ·
Never mind!! I'm going to start a new thread. This is getting a bit off-topic.
Think of it like a female reproductive system and having had a tubal ligation. And fronts could refer to tonsils (tonsil stones) or breasts (implants).👆👇69
