Nice video. Glad you were able to get in there. Once it is in better shape you will notice there is a max fill marker on the reservoir to check you have the right amount.
As the pump is running I would guess at one of two problems:-
1) The leak could be so bad that the pump cannot build pressure. Normally you would be able to see the excess fluid somewhere. Also the pump usually makes a descending tone to my ears when it starts to build pressure and I seem to recall the tone stayed the same when I had a bad leak
2) Perhaps more likely you have a sensor / wiring issue. Check the wiring round the hinges as it becomes a weak point over time. Also check the micro switches (I had one of the metal bars come off - found it in the trunk and was able to re-attach it).
If you know someone with an advanced scan tool there are convertible top diagnostics that will show what the control module is sensing
Hope you get it sorted.
