Here's a great and easy way to run seafoam or any other cleaner into your motor through the vacuum line.
This is made using the 2.4L l4 LE5 engine. It may be similar on the V6 motors.
I like this method because I don't have to screw around with my brake booster line.
Now I've already removed the large black plastic cover that was over the engine and looking at the motor you'll see this.
To the left of this photo you will see the Throttle Body, on top of it you will see a PCV valve looking thing (Left Red Arrow) with a somewhat shiny tube leading from it to the right side of the picture into a little block (Right Red Arrow)
Here's a close of up that:
Look closely at the end of that connector, You'll see a little tab sticking out. The arrow points directly to the tab. Simply press that down as you try to pull it out and...
...It'll come apart!
At this point when the engine is running it'll start to run pretty rough and you can hear that tube making a ton of hissing.
Here's a close up of the connector removed so you can see tab and the way it works.
So do this while the engine is running, and have a friend sitting in the drivers seat to feather the throttle. As he's giving it a little gas to keep the RPM up you just start pouring the seafoam in. It'll suck it right up!
After the engine sucks up the last bit of seafoam you decided to pour in, turn the car off and reconnect the tube, simply push it back on and it'll snap right into place. Let it sit for about 5 or 10 minutes, then fire it back up and let it run for a few minutes to complete the process.
You'll see alot of white smoke/steam coming from the exhaust, that's normal. Just be sure to do it outside.
Seafoam
...thanks for the great post...do you worry about the Seafoam causing cylinder wear because doesn't it remove the oil from the cylinder walls? Just asking because I have heard people say that it is a great thing to do and other folks say that it isn't. Thank you - been thinking of doing this on my Toyota Truck because it's starting to get up there in miles...thanks again!
I've heard seafoam can dry seals, but they say you can add it to the oil to help clean internals. But I'm sure running it through a vac line won't cause any problems with cylinder wear. The way I see it is running it once every so often will do more good than harm.
But if your pouring a can in every week then you may experience issues. Another general consensus is that its really more useful on older dirtier engines. I probably jumped the gun on my G6 a bit lol.
I know your post is older but the pics aren't available on any write up you have posted sadly. It seems as though they'd be very helpful. Any ideas on cause or how to get them back up?
