GMC_DUDE said:
Back on topic, I have been reading this and other threads on the steering wheel lockup subject with interest. I'm wondering if GM is using stepper motors for the power assist. These motors have (usually) three sets of windings which are energized in sequence. Energize them in one order and the motor turns one way, power them in the other order and the motor rotates in the opposite direction. Apply power statically to one or more windings and the motor freezes up, and requires a great deal of effort to turn. I am wondering if the microcontroller or whatever is used to sequence the windings is crashing due to some sort of transient spike or other anomaly? The clearing of the condition after 2 - 3 secs. could be a watchdog timer expiring and rebooting the unit.
One test that could help confirm or refute this idea is if those of you who experience this issue could immediately switch off the ignition key the next time the steering freezes. If my theory is correct, you should be able to turn the wheel after shutting off the ignition, although it will be somewhat difficult due to the lack of power assist. Could somebody please try this and report back? Thanks!
actually, i have seen a thread on this in which someone DID do just that and their steering 'returned to normal'.
however, i have tried to 'duplicate' this situation by reaching 40+ mph, putting the car in neutral and turning off the key. out of the three times i did this, twice the car reverted to a 'manual steering' feel which was an increase in effort but still manageable at speed. the other time the wheel 'locked-up' and when applying alot of effort, the wheel actually felt like it was 'fighting back' and shook and pulsated in my hands.
in regards to the motor, i only know that it is a 'brushless type' motor. i thought that maybe it acts like a starter in that when the electrical system is on (car running) a solenoid 'engages' the motor to the column to apply the power assist. if power were to be suddenly deprived, the solenoid would disengage and the steering would be 'manual'. my theory is that for some unknown reason there is a temporary loss of power and the solenoid is NOT disengaging, therefore causing the wheel to 'lock-up' and when power is restored, it returns to normal. just a guess, as i can't find any info on the actual motor type and if it indeed even has a solenoid or how it operates.
my Service Manager told me that the steering column is serviced as an assembly, which includes the "Torque Sensor" and the "Position Sensor". when a G6 came in for the same issue and it DID have codes stored, it was recommended to replace the steering column. GM must think there is something in one or both of the sensors that is causing this problem. in the cars they have done this, they have had no further steering wheel lock-up complaints. the problem is that not ALL cars are storing codes, as was the case with mine. my Service Manager offered to replace the column, but i declined at this time as i would like to be certain this is the problem first.
thanks for the info and if you find anything else, please let us know........
