1 - 17 of 17 Posts
09 G6 GT. anyone have a problem with the cruise not working all the time. the past two days it didn't work and sometimes it did?????
not really any problems besides a burned out bulb that i replaced. everything seems to work fine back there
how many miles do u have and does your auto slop shift work and your pass air bag lite this just happend to me there was a blown modular in the fuse box
bought it april 2010 and it had 42,999. right now it has 58k. haven't really used the auto stick yet. hope it works. it was a rental car previously. i think the pass air bag lite works.
ok. i do have a problem with the brake lights. noticed tonight that they stay on when i have the car in park and running. and when i'm driving it. did some research on google and found out there was a ntsb report on it and also a recall i think??????? any info on this????
there is a recall but my VIN was not covered (according to dealership)....i had my brake lamp switch replaced and it seems to have done the trick. ask your dealership/repairshop if your vin is covered by the recall. btw if you end up having trouble getting out of park, you'll have to push the brake pedal in REALLY far to get it in gear.
Discussion Starter #9
thanks. no trouble with getting out of park ....yet. thats what i said about the brake lights and sure enough that night i noticed they weren't working properly. so maybe in the next few days the park shift thing will happen.. gonna call the dealer and see what's up
Very common problem. Just clean connections on Body control module by unplugging and reconnecting a few times, and put some dielectric grease in the plug, and reconnect a final time.
Discussion Starter #12
bought a new brake light switch/sensor. gonna hopefully put it in this weekend. it is by the brake pedal right????????????
Discussion Starter #13
ok. now the cruise and brake lights work perfect. holding off on putting the switch in till it starts acting up again.
Me too
I realized that my cruise control only worked intermittently a couple months ago. On a long trip yesterday I noticed it again and found out a lot of owners had the problem. My G6 is a 2008 and thus not part of the recall (at least not on the ntsb site). From what I understand the first recall was in Jan 2009, so wouldn't it make sense that my 2008 would have the same problems as the 2005 and 2006 models for which a recall had been issued?
Well I decided to go with the cheapest option and put some dielectric grease on the BCM. Under the recall info it says "DEALERS WILL APPLY A DIELECTRIC LUBRICANT TO THE CONNECTOR TO PREVENT CORROSION. THIS SERVICE WILL BE PERFORMED FOR YOU FREE OF CHARGE. THE RECALL BEGAN ON FEBRUARY 17, 2009. OWNERS MAY CONTACT PONTIAC AT 1- 800-620-7668 OR OWNER CENTER AT WWW.GMOWNERCENTER.COM."
I'll keep you posted to let you know if the problem persists.
1 - 17 of 17 Posts
