2006 G6 GTP 3.9
Okay so I am the second owner of this vehicle and have had it going on four years, however last summer after some heavy rain and going through what seemed like "okay" depth of water to drive through, my car has been having intermittent starting issues. I found corrasion in the fuse box under the hood "not crazy but just concerning" and clean out all the relays/fuses with electrical cleaner and a brush, eventually replacing all the fuses/relays, and cleaned the connectors/wiring as well. The car does not stall, made it about 300miles (first started during a trip and had to make it back home) but only will you kill the engine is when the tricky parts kick in.
Recently:
The first code it threw out resulted in replacing the fuel pump, that of course did not correct the issue and the next issue came from a failing battery/cells, still cranked, drove around for a decent amount of time, no engine light appeared until I would cut off the car the car and/if I attempted to restart the car either from getting gas or going to the store there would be no crank but the lights on the dash would still come on. I noted it seems worst during the day/heat rather than at night due to making a note of the heat coming from the vehicle itself but after inspecting the fusebox's and not seeing anything melted/burnt and letting the vehicle sit for a period of time depending on the heat of the day/night it would eventually start/crank, unless I unplug the battery and let it sit for about 20mins, allowing the memory to reset then the car acts decently for a period of time.
After the fuel pump I cleaned/checked the ecm connecters and ended up getting "error" on the dash for the very first time which resulted in me trying a new pre programmed ecm but did not take and eventually had to take it into the dealership due to one of the harnesses not making a connection, they were able to get the wiring fixed and I had purchased a new ECM online that required programming at the dealership, for whatever reason the programming would get stuck at 80% and not go forward. Since the original ecm was communicating and the dealership assured me the issue had been resolved after warrantying the new battery due to "failing cells" the car did good for about two weeks and then everything happened again.
Recently:
The codes relayed to the purge valve/fuel efficiency (broken when the fuel pump was replaced) and code P0420 (catalyst system low efficiency) [newest code to date] and was told to start with the O2 sensors and the purge valve, however issue continued even before displaying the engine light again (will get it checked if I can in the morning).
after replacing the sensors and purge valve I noted the heater was not kicking in "blower was working" but the A/C was doing fine, now the heater works but the A/C works for a bit then goes hot.
Reason why I feel it's the ECM/Heat related:If I make a quick trip down the street the likelihood of me experiencing the issue(s) after having the car sit usually over night I can make it there and back home with no issues, it's only when I drive for a good period of time or go out in the heat of the day, the car does not stall once the engine is going and the thermostat gage on the dash does not go into the red and stays steady in the center.
during the time of letting the car "sit/cool down" once it acts up I have tried a few things, checking the sensors under the hood, relays, fuses, connections etc. but the only thing that will most defiantly work is unplugging the battery for about 20mins and reconnecting it to reset the ECM gets everything up and going like nothing.
So I seem to be stuck in a conundrum and the reason why it has gone on so far is because I had surgery back in September an had to put everything on hold until here in March, I am tempted to order another pre programmed ECM (via VIN) and try that one more time now that there is some communication or should I try and see if reflashing the original one would work? I don't see how it could be anything else since the starter & alternator have been checked numerous times along the road now and the relays/fuses were replaced last month too and that it doesn't stall on me while I am driving from A to B no matter the distance and as far as heat I have never seen smoke come from under the hood or seen anything to be melted/exposed so it's all tricky...
