I have a 2007 G6 Value Leader (aka BASE Model), and I want to hook up my iPod and/or get HD Radio, I was looking at the iCarKits, but my current radio does not have a "SAT", "BAND", "XM" button, so I figure it wont work. I want to maintain the functions that are in the current radio, ie. Oil Life, Trip, MPG, Clock, Lock Settings, etc. From the reading I have done, it looks like my only option is to replace the entire radio with expanded model.
I found some on ebay that have the buttons stated above, and have a 3.5mm jack for iPod, are there other options?
http://cgi.ebay.com/ebaymotors/NEW-PONTIAC-G6-2007-2009-CD-XM-RADIO-FRONT-AUX-_W0QQcmdZViewItemQQitemZ140439825128QQptZCarQ5fAudioQ5fVideo
http://cgi.ebay.com/ebaymotors/Pontiac-G6-2006-6-disc-in-dash-CD-Changer-radio-Monsoon-_W0QQcmdZViewItemQQitemZ390227313616QQptZCarQ5fAudioQ5fVideo
http://cgi.ebay.com/ebaymotors/Pontiac-G6-07-CD-player-radio-UN0-TESTED-Ready-_W0QQcmdZViewItemQQitemZ390227358797QQptZCarQ5fAudioQ5fVideo
Can a 2008 or 2009 G6 radio go into a 2007 without issues? I saw the newer radios that are blue like other GM cars rather than red.
Will I run into issues because I have the Value Leader model?
Can you swap out everything for a non-GM radio and still have control over the Oil Life, Trip, MPG, Clock, Lock Settings etc.?
Are there other places to get the radio other than eBay?
Does a new Radio need the be activated...?
:confused:
Thanks for any help.
I had HD radio before via Direct HD tuner. HD Radio isnt very good and I wouldnt put a priority on it. HD Radio is NOT mandated by the FCC like it was with TV. Therefore HD Radio will die off in the near future. Just a heads up it wont last!
Now Satellite Radio will be sticking around...
As for Ipod controls- I would recommend Parrot Products. I will be going with them.
I MKi9100 is what I will probably end up with- maybe the 9200.
http://www.quickconnectproducts.com
Buy it all here and save!
And best yet... You get Bluetooth hands free... and USB control!
· Professional geek
Put basically, you have two options:
Option 1:
Find a used >NON-Monsoon< original head unit (the Monsoon radio needs an external amplifier, so if you bought one you'd have a lot more work to do). You can find them all over eBay, and there are a few auto dismantlers online that sell them as well. It will cost you about $100. You can also buy a new one, and it is also possible to find some reconditioned units.
Next, install the radio in your car and take it to a GM dealership who can program your car to recognize the replacement. Cost will be between $0 and $100.
Buy the aftermarket Aux/iPod/whatever adapter that you want and install it, cost $95 - 150 plus accessories (HD or satellite tuner, etc.).
Option 2:
Buy an aftermarket head unit, cost $50 - 1000.
Buy a Metra or Scosche mounting kit. They have them available with replacements for the Driver Information Center so you can keep those readouts. Cost about $125.
Buy the chime/warning replacement adapter if you want to retain those functions. Cost about $100.
Buy new speakers since your head unit will probably blow the stock ones pretty quickly.
~ MattInSoCal
