I have an 05 G6 and been noticing some issues with the car when I start it. It doesnt happen every time but it seems like the starter is misfiring. If i replace the starter, will the problem stop? Can I expect any other problems?
Any help would be great before I have to pay out for some major labor. Thanks.
Are you referring to the delayed start when it hiccups before it finally cranks over? Do you have remote start? This happens on my 05 G6 as well no matter if I start with key or remotely. From my understanding it is a slight delay with the fuel pump clicking on. Once you go from ignition off > acc you can hear the fuel pump click on if you listen closely. Try turning the key to acc for a few seconds before cranking it over to allow the fuel pump to turn on.
I am not sure if this is the same problem as mine or not. I am just guessing. I've also been told this is fixed with a PCM update?
