If your car is remote start capable and your key fob has the remote start button, check the DIC to make sure remote start is enabled. To do this press the MENU button on the radio to step through the options until you reach REMOTE START. When you reach that option, the DIC will show OFF or ON. If it's off, press the ENTER button to cycle it to "ON", then press MENU to save it. (FYI, the factory default setting is ON.)
Good luck. - Mark
In addition to the DIC procedure, listed above, you may have to add a jumper where the hood switch would connect to the BCM. (Or add the hood switch, if you don't have one. Either way should work.)
Remote start generally requires a hood switch, so that you can't start the car while someone is under the hood, working on it.
