41 - 56 of 56 Posts
If you look on your radio screen, and click the button "info" and flip through the options, it will either say "remote start: on" or "off". If this isn't an option, then most likely your G6 didn't come equipped with it.
Mine came equipped but my remote start doesn't work. I heard the factory starters suck anyway. They usually go out quickly and don't have a very long range, you basically have to be standing right next to the car to get it to work. :/
Hopefully this helps.​
I can confirm the terrible range.
If I am in an open parking lot I can maybe get ~60 feet...A friend with an aftermarket starter kit, easily got >150ft.
Not sure if anyone is still reading this thread but I have keyless that works great and I recently called the dealer to run my vin to see if I had remote start and low and behold they told me my car doesn't have keyless or remote start! But I clearly have 100% factory original keyless and my fobs have the + on the back..... So now explain that!
My GTP has a manual transmission and I have to put the shifter into Reverse in order to get the key out. Unless I did some did some hard core rewiring, I will not be able to get remote start on it.
Not sure if this is labeled on your switch or not. Just thought I would throw my .02 cents around.
Sent from my iPhone using AutoGuide.com Free App
I believe that functionality can be added into the BCM. Maybe that's how you got it? Do you still have the window sticker that came with the car. It'll say it in there as an option I believe. There's also a site where u can enter your vin and get a free printout. Its not a carfax, but it lists your options and rpo codes. I think its www.compnine.com
Sure you can have a remote start. Just gotta bypass the clutch switch and make sure its in neutral with the e-brake up. Unless you can't pop it into neutral without the key, which could probably be solved with another bypass.
Well, all that wiring is beyond my expertise. Lol. And it would cost too much to have that professionally done. I will just be content with a cold car for the first 5 minutes going to work.
G6 GXP
My factory remote start works from over 300 feet away, through building glass and other cars, from the third floor of my building. I use it every day about five minutes before I leave work. I park my car about 250-350 feet (depending on what spot I find) away from the BASE of my building, and then from the third floor, behind glass on the inside, I can start my car easily. :D No aftermarket system on my car - it's all stock from the factory. Maybe the GXP model has more range, but I doubt it.
Of course, I also bought new batteries for my keyfob after I re-soldered the battery holder back in place on the internal circuit board (using directions I found on this site, no less). :cool:
Oh, and it also worked through the driving, 2"/hr snowfall we had yesterday afternoon in Chicagoland - and that parking spot was one of the further ones I've gotten recently (though not quite the furthest).
Remote Start Fix
I was looking around on here because my girlfriends 2006 G6 GT remotes would not unlock her car. Read all kinds of B.S. and figured out that the K.I.S.S. principle was in order. Before buying anything look around your house. Find your aluminum foil and crazy glue. Cut a piece of foil the size of the button on the backside of your rubber cover. Cut out a tiny piece of foil the size of the button and glue it on there. She now has two working remotes and didn't spend a dime. Hope this helps someone because i had to sign up just to post this. You wanna work on something that's a real pain and complicated try a Jaguar. LOL what a pain in the backside.
if i give you the last of my vin. can you or willing to tell me?
Can you help me mine is 64119 9:05
I don't believe this member will be able to. They offered this help in March of 2008, over 10 years ago, and have not been to the forum since 2009, also over 10 years ago. If you have a specific question, please start a new thread with your question (instead of reviving an old one), and the members here will try and help if they can.
Hello,
I just bought a G6 and love it. I bought it used an 06 V6 standard model. I did not receive the keyless entry remote. So I thought I would just go purchase a remote starter with keyless entry. After doing some research I discovered some G6's come standard with a remote starter. How can I find out if my car has the remote starter already installed?
Also, anyone know where I can download a pdf of the owners manual?
Thanks
My ‘09 came with a keyless remote, doesn’t work very well at all. I’ve got to be right next to my car with the remote pointed at the door in order for it to work
41 - 56 of 56 Posts
