I have a 2006 G6 Gt and my two keyless remotes with auto start are worn out. I need two new ones and where should I get them. It seems that the ones with the autostart are harder to find. I find them on Ebay or other web sites, but they say if yous has the auto start then this one wont work for you. Should I just buy new ones? If yes, where is the best place to buy, and not eat a hole in my wallet? Thanks, Mike
I had the same problem as you; mine were worn out as well. I just purchased a new housing off of eBay, put in my chip and it worked perfect. As long as it has the autostart feature button at the top of the remote, then it will work!
It could be the connections that are soldered to the board, both mine had atleast one broken connection and I had to re solder them into place. Worked perfect after that.
