Hi everyone, I have a 2008 G6 (3.5) and after about 55,000 miles I had my first major issue. Long story short my positive battery cable corroded to the point where the car would no longer start.
I installed a new battery cable and the car is running great BUT my keyless remote/alarm is dead. My key fob wont unlock/lock/truck release although all of these functions work from inside the car. When it's locked the alarm doesn't sound when I unlock it and the only other thing I have noticed is my Tire Pressure Monitors aren't working anymore. When I cycle through the Info it just displays "-" instead of numbers.
I've checked most of the obvious fuses and they all seem to be fine. So...is it time to take it in? Any thoughts, ideas would be appreciated!
Thanks
The remote control door lock receiver is also the receiver for the TPMS. Since this occurred immediately after a batt cable replacement, I'd check it's fuse again carefully (fuse 16 in the trunk fuse box). No lights or messages on the instrument panel?
No lights or messages. The fuse looks fine as far as I can tell but I'll go ahead and pick up a new one and give it a try. At least I know where to start now. Thanks
The RCDLR may just need reprogramming. But, of course, that requires a dealer.
Service Information 2008 Pontiac G6 | G6 (VIN Z) Service Manual | Document ID: 2176461
#08-03-16-001B: Key Fobs Inoperative, TPM System Not Reading Correctly - Dashes on Al Four Tire Readings, DTCs C0775, C0569, B3105 Set, Unable to Program TPM Sensors (Reprogram RCDLR) - (Jul 31, 2008)
Subject: Key Fobs Inoperative, TPM System Not Reading Correctly - Dashes On All Four Tire Readings, DTCs C0775, C0569, B3105 Set, Unable to Program TPM Sensors (Reprogram RCDLR)
Models: 2008 Chevrolet Cobalt, HHR, Malibu
2008 Pontiac G5, G6, Solstice
2008 Saturn AURA, SKY
This bulletin is being revised to update the Important statement to reflect the new direction to no longer contact TCSC. Please discard Corporate Bulletin Number 08-03-16-001A (Section 03 - Suspension).
Condition
Some customers may comment that the key fobs are inoperative or that the TPM system is showing dashes as the reading for all four tires.
Technicians may find DTCs C0775, C0569 and B3105 set simultaneously in the RCDLR module.
In addition, the technicians may find Tire Pressure Monitoring sensors are unable to be programmed to the vehicle by adding or releasing pressure to the tire while the vehicles in the TPM learn mode.
Cause
These conditions may be caused by the following:
• The RCDLR may lose its transmitter and tire pressure monitoring data from its memory if a low voltage condition occurs on the vehicle.
• The ability for TPM learning by adding or releasing pressure to the tire has been disabled in the RCDLR.
Correction
Reprogram the RCDLR with an updated software calibration to address both issues listed above. This new service calibration is available on TIS2WEB using Service Programming System (SPS). As always, make sure your Tech 2® is updated with the latest software.
Important: If the Tech 2® could not establish communication with the RCDLR AND the programming event ended with error, attempt to reprogram in Service Programming System (SPS) by selecting "Remote Control Door Lock Receiver (TSB 08-03-16-001) with E4399 error -- Pass Thru Only".
Once the RCDLR module has been reflashed with the latest software and calibrations, the following may also be necessary:
• Relearn all keyless entry transmitters.
• Reconfigure the tire pressure placards and the tire type.
• Relearn the tire pressure sensors.
Refer to SI for the procedures to relearn transmitters, placard and tire type configuration and tire pressure sensor learn.
Warranty Information
Labor Operation
Description
Labor Time
R4481
Remote Control Door Lock Receiver (RCDLR), Reprogram with SPS
Use Published Labor Operation Time
Add:
Diagnosis Time
0.0-0.3 hr
And here's another bulletin:
Service Information 2008 Pontiac G6 | G6 (VIN Z) Service Manual | Document ID: 2084188
#PIC4757B: Remote Keyless Entry / Tire Pressure Monitor Inoperative - keywords inop inoperative int intermittent loss memory programming RCDLR RFA RKE RVS start TPM - (Mar 19, 2008)
Subject: Remote Keyless Entry/Tire Pressure Monitor Inoperative
Models: 2008 Chevrolet Malibu (new body style)
2008 Pontiac G6
2008 Saturn Aura
This PI was superseded to update models. Please discard PIC4757A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
There is a current Remote Keyless Entry software concern that could cause the RKE and/or TPM to become inoperative. During the diagnostic process you may NOT be able to find the RKE module on the list of available modules in the Body section of the Tech-2. This is caused because the RKE module is NOT communicating on the G.M. LAN system.
Recommendation/Instructions:
If you have the above concern please verify the inputs to the RKE Module and if they are all ok replace the RKE module.
Note: This issue is supposed to be addressed in a future version on Tech 2 software.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
