Interested in LED 3rd Brake Light Kit
1 - 20 of 21 Posts
Hey All,
New to the forum and would like to get some input on interest. I have made some custom lighting projects for a number of vehicle communities and one of the main things that I have done for most of them is LED 3rd Brake Light Kits. I have wanted to check out the G6 for quite some time since they have a similar assembly to that of the Grand Am/Alero and the Cobalt, all of which I already make.
Here is a pic of the ones for the Alero/Grand Am
Input/Comments welcome. Let me know if there is any questions. I would also like to see if someone would like to volunteer to measure their 3rd brake light assembly. If it is really the same as either the Alero or Cobalt, the ones I already make should fit perfectly.
Also, Price point on these would be $25 shipped for the single strip. (1st Pic)
Thanks!
~Bryce
Hey All,
Thanks!
~Bryce[/QUOTE i want one!!!!! i ahd an alero and i wanted one for that car.
PM me with the measurements you need and i will get them.
jonathan
Hey All,
Thanks!
~Bryce
I want one......PM me with the measurements you need and I will be more then happy too get them.
I would definitely be interested in getting one of these for my 3rd tail light. I'll see what I can do to get those measurements for you- the light housing is a bitch to get off so I'll have to get creative with it. The washers holding the bolts in are in pretty deep and I haven't found a tool yet that will take them off (and of course the owner's manual doesn't do very well to describe removing them, go figure). Look at the picture below- any suggestions anyone?
The actual light itself from the outside measures just under 11.5 inches, but I'm not sure if that helps at all. Also attached a pic of the outside look.
Thanks for posting this :)
Discussion Starter · #9 ·
I would recommend a deep socket...if I remember correctly the Alero/Grand Am ones were a 10mm. As for the measurements. I need the inside ones for the reflective housing. They sound pretty close to the Alero size, but I would need to be 100% sure. Let me know how you make out.
~Bryce
~Bryce
Will do! Thanks for your help :)
i would definitely be interested in one of these kits and i took off the light and it looks like that it is 11.5 inches from the edges of the reflector housing on my 2007 g6 gt
Great, so the inside reflector behind the red lens is 11.5" in length....how about the height? I assume probably 3/4"? Let me know and I will get one fabbed up.
Bryce
Hey i posted pics of the g6's 3rd brake light in the gallery section the title is " 2007 g6 3rd brake light taken apart hope that'll help
I like the single with doubles....or the second picture and would be interested in that.
It comes with a resistor so the car doesnt think the bulb is out, correct??
Make me one....I'll buy it.
I will buy one also
1 - 20 of 21 Posts
