21 - 33 of 33 Posts
no resistors, they just straight up switched out and work fine. i got them from autozone. im not sure the part number, ill run and check here in a couple min after the gf gets back with my car. the package is in the trunk still lol but they were kinda expensive. 17 bucks for the pair so idk if thats in your price range or not...
· Procrastinator
So for the brake light, what color led's should i go with? its a colored lens so does it matter if i use white? that way it would be brighter
Go with red LEDs. I have worked with LED bulb replacement at work. I have used white and red LEDs behind red plastic panels. The Red ones stood out much better than the white ones. The red on red amplifies the brightness. I couldn't tell you what type of LED I used, but red on red definitely worked better.
I find for the dome the circuit board leds work the best. Check oznium.com v-leds.com Ebay
And autolumintaion.com They all have great products when looking for LEDS
The dome map uses a feston type bulb. But the circuit boards come with diffrent attachments you can even use them in the maps lights I have some on the way.
21 - 33 of 33 Posts
