http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/would 3157's work for the tail lamp and what size bulbs do the stop lamp use?
The tail lights are a combination stop and turn signal in one bulb, The 3157 is the same as the 3057 bulb. A 3157 would work.would 3157's work for the tail lamp and what size bulbs do the stop lamp use?
What is the bulb number. If they are 194's, I have a bunch and can send you some. I think the upper light takes 3 or 4 bulbs. Let me know.i was wondering actually if you could replace the bulbs in the secondary stoplight/high mount stop lamp with leds...so i was figuring that i would go to kragen or something and pick up some 20 led bulbs but i guess they arent as good as 30's? does anyone know of a site or store that sells these led bulbs (non crap version)
idk what size the hmsl uses cause all it says on the sites that lists the bulb numbers are "assembly" it looks like the hmsl uses 3 bulbs but the problem is is that you need some weird sized socket wrench to take them out it, it's like they use some in between size? but all the lights in the car are pretty much either 3057's or 194's and looking at the size it seems that a 3057 would be too large...so maybe it is a 194?What is the bulb number. If they are 194's, I have a bunch and can send you some. I think the upper light takes 3 or 4 bulbs. Let me know.
Steve
