Pontiac g6 turning signal: when I start the engine my turining signal is working and everything is ok. However after some driving it starts to blink really fast on inside and not working on outside (only left one, right one is fine). It does not work until I stop and reset the engine. After that it is working for some time again. However if I am driving a lot it seems like there is high temperature in instalation and even if I reset the engine it works only 1-2 times. Any ideas?
Try checking the 2 harness connectors to the BCM, gotten to by removing the console side panel on the passengers side. Also get some dielectric grease and put it onto the harness connectors wire pins before putting back together.
