My '08 GXP (bought used) has a "locking" lug nut on each wheel. I'm guessing it came that way from the factory.
They are round on the outside so of course no standard wrench will work; but on the top surface is a wavy circle meant for the special socket to fit.
The problem is, I don't have the socket. At least it's not in the glove compartment - perhaps it is with the spare tire uquipment under the trunk, but I haven't looked there yet.
Worst case scenario - are replacements available? Could I get one from a GM dealer?
Thanks.
Perfessor
If they were installed by the dealer originally, they may be able to replace them. Otherwise you'll need to get them split to remove them. You should also replace them with a new set of locking lug-nuts. When I got mine I got 2 "keys" with them, so I keep one at home and one in the glove box.
