1 - 20 of 23 Posts
My names Mike, I have been browsing these forums for quite some time and finally have a good reason to post. I have a 2009 Pontiac G6 GT with about 74k miles on it. Before I even get into the issue, let me say I have not added anything to this car in regards to stereo system, alarm system, anything electrical, etc. The only additions have been strictly cosmetic. So about a month ago, I woke up and went out to get in the car to head to work and the car wouldn't start. I got a jump and headed to a local garage where they informed me the battery had a dead cell. Fair enough, I went to Auto Zone, got a new battery and everything is great!......No... well now about a week ago my LH headlamp went out, I replaced the bulb and everything seemed ok, the next day it blew again. When i went to replace it this time I noticed that the plug (with the wires) that actually plugs into the bulb assembly is melted? I took a wire brush thinking maybe it was just corrosion, but it is definitely melted. went with one headlamp for a few days and now the passenger side went out, I took it out and it too is melted. I called my local dealer to check on a wiring harness and he said the wires I need with the plug do not come with the harness and are only available with a new headlamp assembly... both sides will run me $300+. Has anyone else experienced this? Any suggestions?
On a side note- I sell Aftermarket OEM replacement collision parts for a living and I have never seen an aftermarket one for a G6 that came with any type of harness whatsoever, so that is out of the question :(
You need a repair plug, should be able to find one at a local parts store. I know Advance Auto sells them, it just needs to match your bulb socket..
I tried Auto Zone..
I had the manager at Auto Zone come out and take a look at it along with one of the other workers. After we half-pulled the cover off to get the headlamps out, he said they did not have any kind of plug that would interchange for what I was needing. I also checked with Napa. Both lamps had the OEM bulbs in them as far as I know, the car has never been in an accident and the headlamps have never been replaced. It was very odd how the LH side melted a week before the RH. It made me wonder if there is possibly a short somewhere? I ran a drain test and it came back good. I'm at a loss at the moment, can't afford to spend that much on new headlamps at this time... When the LH first went out, I didn't think it was the bulb because it still looked ok (the springs were still good and everything). So I probably threw my OEM bulb away for no reason...
Here's the OEM part # for the low beam headlamp connectors (both are the same). Not sure if this will help you much.
GM 15393198
Greenman
@ Greenman, I appreciate that, unfortunately that's a partslink number, the dealer is not able to cross those numbers. I took my car into a local dealer yesterday and actually had one of the guys in the service department come out and look at it, we didn't pull it out but i did explain it to him and he said I would have to get the whole headlamp assembly. What a pain in the ass.... :(
Storm Trooper
sounds like a unique issue. never heard of that. what you can do is get some aftermarket headlights. we finally have good ones but DO NOT BUY SPYDERS they are like shining a 3watt bulb through mud. they look nice but if you drive at night you will die
Lampoon has the new set and i am sure he would point you in the right direction.
Also can you show me pictures of where it is melting? is it the main harness that connects to the headlight unit or the harness that connects to the H11 bulb?
Discussion Starter #8
@ Tupperware, it is the harness that plugs into the bulb, I will try to get a picture of it posted within the next day or so. Every one I have talked to is saying they haven't run into anything like this before on a newer car... I can get brand new DEPO or TYC (CAPA Certified) OEM replacement aftermarkets from my work for cost, but they do not have any part of the harness with them, it is just the headlamp assembly itself.
Discussion Starter #10
@ Tupperware, man I appreciate that, don't gut it yet though. Let me post a picture of what I am working with so you can see what's going on. I have never seen them do this before, very strange. I will try to get a picture posted sometime this evening if I can. Thanks Again!
Discussion Starter #11
Just to make sure I'm on the same page as you guys..
The arrow represents the plug that is melted on my car. That plug has two silver contacts in it and the plastic is melted all around them. I just wanted to post this to make sure I wasn't sounding like a dumbass trying to describe this to you guys.
Thanks!
Storm Trooper
that is not a problem. i will go home and gut the spare light housing i have. i can send you the guts if you give me shipping. real shipping not a general postage fee. i think the USPS has a flat rate for under $10.
also if you go to G6P there is a guy named BlueGTP33 who used to paint headlights for people and i am SURE he has parts piled up he would love to sell or get rid of.
Shoot me a PM and we can work out the details.
Cheers
Discussion Starter #13
@ Tupperware, I don't think gutting your headlamp will get you the piece that is melted on my car. The piece that melted is not attached to the headlamp itself. **see pic above**
Thanks!
Storm Trooper
i know. it is the wire harness within the unit. it has the connector for the High, Low and turn signal. then it exits in to a 5 pin white harness that is on the outside of the unit protected by a rubber weather plug.
Right?
hell i will rip it out and take a picture and if you dont want it then NBD. honestly it is just a single headlight that has been VHT tinted but the guy who did it tiger striped it so i was never goign to put that on my car. now it was goign to be internal replacements (if needed) it has been 2 years and it still sits there.
no harm done.
The headlight harness is inside the headlight housing on these cars. I'm not sure it's replaceable without pulling the housing apart. Also, I looked at a parts site & they didn't list the harness separately so I suspect you'll need to replace the whole smash if you don't want to pull them apart & use a salvaged harness.
Whatever you end up doing, you need to ensure both connector mating surfaces are completely free of all corrosion & then coat them with silicone dielectric gel to lock out water. It makes all the difference in the world. The connector is supposed to be water tight but humidity still gets in & condenses on the metal surfaces.
I bought brand new wiring harnesses for like $12.
You could splice it in easy cheesy but you need to find out what caused it
or it will probably happen again.
Check your electric box....your circuit breaker should have gone prior to
any melting....
12 bucks. That has to be aftermarket. I wonder how they hold up over time.
The breaker usually won't open because the heating is localized & there's little change in current draw. The headlamp itself performs the circuit protection in these cases. Pretty common problem.
Professional geek
Melting comes from heat, which comes from lots of power being dissapissatated at that point. The connectors to the bulbs would melt because the contacts between them and the light bulb had too much resistance. It doesn't take a lot of resistance to lead to high heat levels when a lot of current is flowing (35 Watt bulbs are pulling about 3 Amps each). The higher the voltage goes into the same resistive load the more power is consumed, and the more heat is generated so it makes sense that the headlights failed so soon after replacing the battery (the damage to the connectors was probably there for a long time). I'm amazed that you have a hard time finding the repair connector as it's not like the G6 is using some non-standard bulb.
Greenman's suggestion to use dielectric grease is a good one and I'd second that.
Oh, and welcome to the site as an official participant instead of a lurker!
~ MattInSoCal
1 - 20 of 23 Posts
