The lowbeam headlights recently started staying on when I switch the highbeam headlights on. I know they used to turn off when you switched to the highbeam, as do a lot of GM vehicles and other Pontiac's I've owned. The DRL's are working when they should and the headlights come on and go off automatically using the ambient light sensor. I have noticed though that the lights do not want to turn off if you are driving on a cloudy morning. They will turn off if you are in sunlight, but that doesn't seem to be how they used to operate.
I'm wondering if the body control module could be the problem, since it is controlling the headlight relays.
Thanks
Thanks
