1 - 1 of 1 Posts
Hey everybody.
I own a 2008 G6. I got this repossessed.
It looks like the previous owner hit a dip pretty hard, and there was only one point of impact on the bottom of the car. The only part damaged was the lower radiator support. That piece bolts on to the frame along the bottom.
The actual support on the passengers side is all bent and not usable again. The one spot on the frame where you bolt the support to is also smashed in, put the bolt holes at a weird angle. So, since that piece is bent, I cannot reattach the radiator support. And that support is the only thing holding the radiator up on the passenger side of the car.
What should i do? permanently weld a seperate piece of metal on to hold up the radiator? Or should i try to pull out the smashed in piece of frame?
1 - 1 of 1 Posts
