Hey i gotta 2006 g6 gt and i believe is something wrong with my manual gear whenever i use manual i cant get it past the 4th gear wont shift to 5th let alone 6th it jus goes to 4 and only goes a little bit past 120 any suggestions on the problem?
Sounds like you have an auto trans, and they are in fact 4 speed units, so that's not unusual at all.
Yessir 4 speed automatic but even in auto the speed limits the same I thought manual would let me up a gear. So i wont be able to use the last 2 gears?
I'm confused. If you have the 4 speed automatic you only have 3 forward gear lever selections to shift manually. L-3-D. You would need the OPTIONAL 6 speed in order to have 5th and 6th gears to manually shift into.
Super Moderator
2006 GT should only have a 4 speed trans. Sounds like your hitting the speed limiter. You gotta get the removed of you want to go faster.
