Is there anyway to tell if the amp is bad for sure. I have an 08 gt coupe with Monsoon and everything is working except there is no sound. I think its the amp (passenger side trunk). Amp fuse is good. I had a lot of moisture when i pulled the carpet back to get at the amp. Where is best place to get a oem monsoon amp for this? Dont want to spend alot of cash on it cause its just a work car but I drive anywhere from 1.5 to 2.5 hours one way. Need music. Help a guy out. Thanks,
Steve
Thanks waterfowler but that isnt the same amp. Mine has three groupes plugins of wires going into the amp while that one had two.
It is the Amp, I just replaced mine. Good luck I could not find my amp that matched the serial number for less than $200, but man it sounds good when it in.
Yea I think that is the one. Numbers dont match but it looks like its the same. Would it matter if its a sedan or coupe amp?
Grab the part number off of yours a search it on ebay. I'd also call a dealership and ask for a price. It will probably be expensive but just incase the part number changed, you can atleast get the new part number.
