I purchased the car with this problem and have not been able to figure it out. I haven't found much information online about a problem that's similar to either. What happens is I going to start the car the car starts up and then the car shuts off on its own sometimes it'll run for 30 minutes sometimes it run for 5 seconds. I've checked all the relays and fuses in the fuse boxes everything seems okay. I'm now leaning towards the ignition switch or some type of security problem. Please help Jim
3.5 L there are no special lights no check engine light on it'll run intermittently sometimes after I started a run 5 10 seconds and shut off and then it won't let me restart it for a minute and sometimes it'll stay running for over a half hour before it shuts off. There is no distinct smells and the car runs fine when it is running even when it's the shorter. Of time
I’m having the same problem! Tried the crank shaft sensor, no luck. Went to do the cam shaft but it’s behind the passenger tire NOT the starter. When removing the started another part crumbled in my hand. Did you ever get yours fixed?
Related Threads
Pontiac G6 Forum
142.8K posts
38.7K members
Since 2004
