1 - 20 of 22 Posts
My G6 just couldn't start after I went to gas up on a local gas station so the car got towed away back to the dealership. I just got a call they said the fuse blew up and it prevent the car from starting but I'm picking up the car tonight lets hope it doesn't happen again!
e2helper said:
Hate to disagree with you but that Megafuse is actually just for the power steering module :p
Hmm, I don't have a mega fuse, I feel ripped...(goes out and enjoys not locking up his steering cause he's got HYDRAULIC steering :D)
Discussion Starter · #10 ·
All right maybe the fuses didn't blew up. The invoice said " found no power AT -S -Terminal when Crank. Found starter fuse #26 open. Checked circuit #6 and found circuit Rub through at AC LINE. REPAIRED CIRCUIT #6 AND REPLACE FUSE TO CORRECT (7J)"
G6Action said:
i HATE you!!!!! :rolleyes:
What are you complaining about, you have a GTR! That's two steps above mine: There's a GTP, GTQ, then the GTR. :D
No you are correct, fuse that "blew" was for the starter solenoid relay. The opening of a fuse is a pretty powerful event - it just stays contained within the fuse itself - you do hear a pretty crisp "POP" when one goes though.
PCB said:
I have a bunch of 800 amp 1000v fuses.. What ya think I could get for them?? LOL
i think Ralphy would pay top dollar!!!! he wants to 'upgrade' his megafuses to increase low end torque and cornering. as we all know, you need AT LEAST
4000 amps for that application. if he adds the "Brembo Quad-Piston Electronic Calipers with Dual Vented/Drilled Discs on each wheel, he'll have to add another
2500 amps per wheel for a total of 14,000 amps. do you have enough of your 800 amp, 1000v fuses on hand to do the job? needless to say, he may have to mount a portable generator in his trunk to supply enough power to operate all his 'mods'.......and we haven't even discussed "what system" he has!!!! :rolleyes:
1 - 20 of 22 Posts
