1 - 9 of 9 Posts
I have a g6 gxp
found a brand new set of MSR 18 inch blacked out rims for $500
needing to know if 5x115 will work.
any rub? special lug nuts? brake capiler modifications?
look good?
Good lookin wheels dude. Unfortunately i cant help with the sizing or fit issues, but i can tell ya they should look good on ya gxp. Prolly wanna use 225/45 on em to make sure of no rubbing and if they fit on ya hubs then that tire size should fit rather nice from what i see on sizing
Hey man been looking this issue up and from what i see, everything says the g6 bolt pattern is 5x115, exactly what these rims are
Damn man i googled it and it says its 5x115 and talked abt 5x114.3 working. I sure didnt wanna steer ya wrong. Like that commercial says "dont believe everything ya read on the internet"...damn french model lmao
The g6 bolt pattern is 5x110. Wheel adapters would work fine because you are going from a smaller spacing to larger. They are dangerous if you are doing the opposite. The only thing I don't like about the adapters is you have to decide on a 2" thick adapter or cutting the lugs shorter and then replacing them if you want to go back to stock...
Sent from my Note 2
1 - 9 of 9 Posts
