1 - 19 of 19 Posts
Kash
hey i have a 08 g6 gxp with a stock head unit and i want to put in a pioneer indash head unit but i was wondering is there any way to get the tire pressure oil life and all that other stuff working when taking out the stock radio
your DIC can be saved but you will need the metra or scortch (sp?) kit.
Do a search for metra on here. Lots of info with pix and part numbers.
Mobile Audio Specialist
Here
You need the following to replace your factory radio.
PAC 0S-311B GM Radio Integration Adapter.(MSRP $190.00)(This will retain door chimes,turn signal noise and car notificationsand allow you to run sound through the factory speaekrs.)
Metra 99-3303 Radio dash kit. MSRP$180
I'm assuming you have the Monsoon factory system*
whats the PAC do? reroute the sounds?? I thought the BCM regulated that through the speaker attached to the back of the speedo cluster....??
It would be awesome to have that sound come out the radio speakers.
BONG BONG BONG..... lol
It does but it plays through your driver side speaker through the radio, If you go through your DIC and make it louder it's much more noticeable
Door Bong, Turn Singal's(yes there digital), Alerts, and Onstar
2005 G6 GT
I went to my local automotive electronics shop and they ordered up the Metra kit for me. The kit alone came to about 160. I also needed a special wiring harness to be compatible with the monsoon system and that came to about 90. So, not counting the aftermarket stereo, it ran me about 250. But looking at other people's prices I apparently got a good deal. :)
Add on another 50-60 bucks if you don't plan on installing it yourself.
i used the metra kit. didnt need any aditional wiring harnesses for my monsoon system. just the kit, my pioneer deck, and the 15$ antenna adapter
that $15 antenna adapter is cheaper at walmart in my area, and even at auto zone its cheaper, i got my adapter from best buy unfortunately and didn't know better. and same for me i didnt need any type of additional harness the metra kit was all that i needed.
Kash
Discussion Starter #9
do i need that shit.. what if i dont care about the bong or the oil life can i just wire it in like a reg deck in a reg car?
Kash
Discussion Starter #15
i dont see what u did i dont understand why i need to spend another 190 for that unit when its not even gunna be in use and why gett the screen i dont see where u can put that in there
i was
well I was going to extended the wires to glove box but its was 25° outside I was cold so I just put it their for now I got an rear view camera coming so I will do that then and weather permitted
I was thinking the same thing at first but after searching for months I found that u going to need two kits I could have used that PAC thing but I got that 99-3303 for 143 off ebay if you get that pac let us know it works
Google it if you want try g6 performance forum
2006 Black G6 GT
Its a preference.
If you want to keep that little one line display of your oil, trip, mpg, etc...
You can put it somewhere visible like your dashbox or middle glovebox for easy veiwing.
Its not necessary for installation, i did it without.
Kash
Discussion Starter #18
so i dont need it it wont **** with my cimputer like some 1 said so i can just replace my stock radio with my indash no prob like a older car ?
This is all so confusing. So if I wanted to replace my stock single disc Monsoon head unit with say a Pioneer AVIC-X710BT and keep my DIC, but reroute it to say the glovebox, or center console.. what would I need exactly? The entire list of parts? So with the Head Unit costing between 500-600, how much more would I be looking to spend?
1 - 19 of 19 Posts
