My 05 g6 radio died on me and I want to replace it with a factory radio. What I need to know is what radios will fit in my car? 2005-???? and does any other models have the same radio??
thanks you
thanks you
I haven't got the 6 disc out yet, but the one I bought is #15849574. My concern is that its not a monsoon and won't work. Is there a way to find out because taking everything apart?i would think the reason its got a different part number is because its a single disc versus the 6 disk.....what are the part numbers you have?
If the part number thing is a problem I'll give you a shout.Should plug and play just fine. Wished you bought my old radio out of my 06 G6 although it is monsoon.![]()
aww damn then, i heard someone put a monsoon in a non-monsoon vehicle and gm did the programming to make it work. I better just go down to the dealer.If you have a Monsoon sound system, then you will want to replace it with a Monsoon headunit. The number of discs it holds shouldn't matter or the graphics it displays for its buttons.
Well, I'd go ask the dealer since they probably know more than I do.aww damn then, i heard someone put a monsoon in a non-monsoon vehicle and gm did the programming to make it work. I better just go down to the dealer.
Got the radio in the car, went to the dealer today. Just as I expected they say their not sure if it will work, but not only about the monsoon but about the different style(6 disc to single disc). Plus a $100 bill for something they're not sure will work or not.Well, I'd go ask the dealer since they probably know more than I do.
EDIT: Just checked with ALLDATA and you will have to get the new radio reprogrammed for your car. Whether that has to be monsoon or not, I don't know.
I would've gone safe with getting a Monsoon headunit, but go ask. Here are the wiring diagrams of both with and without monsoon.
did you check the fuse? you never know hahaMy 05 g6 radio died on me and I want to replace it with a factory radio. What I need to know is what radios will fit in my car? 2005-???? and does any other models have the same radio??
thanks you
