1 - 10 of 10 Posts
hey i have a 2009 pontiac g6 gt coupe and i dont know how to replace the 6x9 in the back. If anyone could help? Can you post a how to.
Please help..
After typing this out i realized you have a coupe so it could be different sorry
Its not to bad taking the deck apart.
1 take the bench out of the back seat just pull up and it comes out.
2. remove the 4 bolts by where the seats lock in (not sure what that part is called)
3.then remove 2 bolts on each side that are still holding that same piece in towards the bottom of it facing the trunk.
4. Pull out canoe/push clips from deck liner
5. Not sure if you need to but remove the 2 pillars in the back window i believe it takes torque bits
If its seems confusing start taking it apart and read this it will make more sense.
08 G6 GT Owner
Hi all, haven't been on this site for awhile, but i was lookin thru and found this blog. I have the same problem but with my 6 and 1/2 in both doors (2008 coupe). They have been put thru plenty of abuse for the year and a half i've had them for and now they are blown. Im tired of having audio shops hook up my system and I am finally becoming a do-it-your-sefler. If anybody can 1.) tell me how to take off the door panels to get to my speakers, and 2.) tell me how to fix the speakers, I would be much obliged and may start coming back to the site more often like I used to. Number 1 is a must, number 2 I think I can figure out on my own. Thanks fellow G6er's
gotta put mine in too!
I'm in the same boat as you. The people I had do my system did such a bad job that my rear right speaker blew. The place was a legitimate garage that specialized in audio systems, and the guy who did it left his knife in my car, and he attached the converter to the woven wires of the speaker which he sealed with electrical tape. So I'm redoing it and putting some pioneer speakers in the back, and of course I'm going to hook the speakers up to the amp which the guy was too lazy to do. After changing my headlights, I feel I can accomplish anything!:cool:
now to figure out how to disassemble the back part!
thanks daniel for the instructions!
I highly doubt it was the shops fault the speaker blew, especially if it wasnt hooked up to the amp. If he didnt hook it up to the amp(probably didnt know it was there, did you tell him there was an amp?). Wiring it to the spearkers like that isnt good, but most audio shops will only wrap the wire around the other wire and put electrical tape on it.
I gave them the amp to install, and he put this adjustable line converter to hook it up, and even that was jury rigged. I think when the speaker was shaking with the way they had it hooked up, it was arcing and I believe that's how the speaker blew. Now it's just a process to change them.
1 - 10 of 10 Posts
