1 - 17 of 17 Posts
Hi all new 2005 g6 gt loaded with panorama sunroof auto start leather heated seats etc.
New to forums and im having trouble finding answers.
My question is the car didnt come with a key fob and it has an annoying alarm every time i lock my door by pushing the lock button when i start it an alarm goes off. I have to quickly put the key in to turn it off. Now i purchased a new fob and will get it friday - monday. Now is there a way to disable it until i get the new fob.
Next question. My DIC says security mk something and passive. what are the differences?
and last. I would like to put in a new radio a double din and i read this post
http://www.g6ownersclub.com/forum/showthread.php?t=12178
I saw that you can buy a dic from metra- are there any that arent a actual radio slot so i can mount it elsewhere. and the axxess harness is needed for the double din radio correct. just want to make sure i have all the parts i need to make my car mine if i use a double din radio do i need an install kit?
any other help that can increase power/fuel mileage and looks would be great.
Thank you for reading and if you respond i thank you in advance.
Jamie
Welcome to the site!
I'm not sure of any way to disable the factory alarm. All I'm aware of is to lock the doors manually. So it'll be locked bu no alarm active. That can be a pain running around the whole car but it's an idea.
I'm also not sure about the DIC messages. I haven't seen either before.
You can easily put in a double din radio. Some users on here have gotten the metra kit and simply put it some place else. Like the center storage box or the glove compartment.
So it's still there and useful but out of site.
As far as increase Power/Mileage.
Look into getting an intake and possibly a tune.
You can get an intake from CrabIntakes.com good stuff.
And a tune from WAMS
The intake alone should make it sound and feel a lot better and give you some gains in the MPG and HP department. not a lot but some.
If you get it tuned, you can run premium gas and actually see a gain of about 12-15 HP and a gain of 1-3 MPG on average. Though you'll need to buy the more expensive gas in that case
ty
Thank you for the reply.
the message is on the DIC if you cycle menu through it says like reset oil lock horn etc then it gets to security. mk? and passive.
looking for a nice double din radio for a good price and poss the metra kit not sure if it is really needed. but might be good to have.
Thank you again.
Jamie
On an '05, content theft alarm will not enable if you only use the lock lever/lock pin to lock the door.
I'd need the exact wording.
Crutchfield will give you those details & you can purchase the gear wherever.
how can you tell if this car has a built in amp.
im looking at a double din radio and my brother installed one and it had a different harness for an amped radio
Do u have the monsoon stereo or just the plain one. Any double din should work. You can go without the DIC metra kit you'll just loose the ability to change settings and such
Idk about the DIC but I see the thread you quoted was from my post lol you can either get one or the other of those harnesses. The metra one keeps your DIC and leaves a spot for a single din should you wish to use one. Or if you want a double din you can cut off the top slot since it will be useless and mount it somewhere else so you still have access to it. On the other hand you can use just the axxess harness which is what I did. You lose your DIC but its more of a budget thing. The metra piece is about 130 bucks or so and the axxess harness is only 60. It will still keep all your warning chimes and whatnot you just won't have the info center. So its really just a matter of preference and how much work you want to do and your budget.
As far as the amp goes. I don't think it comes with a factory amp but I could be mistaken. (I don't have the monsoon system) but if it does a lot of times they're either under the drivers seat or on the bottom of the rear deck lid in the top of the trunk. And sometimes on the side of the trunk where the fuse box would be behind the carpet.
And for power. Crabs and wams hands down.
-J
Discussion Starter #8 (Edited)
Thank you all for the posts. This is the radio i would like to buy: http://www.ebay.com/itm/120889246468?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_13552wt_1154
To answer an earlier post yes i have the mongoose 6cd changer 200w and the dic message was security:rke or passive
Now i know its not a good name brand lol but ive seen it in action and like it. As for the DIC im not sure if i will ever use it really and if i need it in the future i can purchase the metra one and install it elsewhere my question is what do i need to make this work. Do i need a dash install kit or would this radio fit? Do i need any special harnesses or modules to keep my chimes etc what radio harness would i need. If anyone knows about the amp and can help that would be good im gonna go out in a bit and look to see if i can find an amp is there an rpo code that might show up in the glovebox that would let me know if it has one?
I just want to know what to buy to see if i can afford it and where i can buy it.
Thank you
Jamie
Discussion Starter #10
Cruchfield says this
Installation Details
Installation Details for your 2005 Pontiac G6 Sedan with Monsoon sound system; without OnStar
Fold-down face receivers will not fit your vehicle. Please verify that your new receiver does not have a fold-down face.
The color of this installation kit is black.
You will lose the ability to change certain settings in the factory computer by replacing the factory radio. Please consult your owner's manual for a complete list of functions that the factory radio can control.
You'll lose your factory XM capability if you replace your factory radio.
is the part about the fold down face receiver true?? i believe the radio i want folds down to install cds and stuff
Jamie
I looked at that ebay listing, it does fold down. I'm not sure if anyone else has em. I would think a fold down should still work due to the fact it's mounted all the way to the edge...
Try looking through or posting in the Car Audio thread...
http://www.g6ownersclub.com/forum/forumdisplay.php?f=19
You may have way more luck finding out if a flip down head unit will work.
I'm almost sure it'll work because I've seen pictures of double dins that didn't have a CD slot, so they must have been fold down. unless they had a cd changer in the trunk...
Amp would be behind the trunk liner, pass side, forward of the tail lamp.
Service Information
2005 Pontiac G6 | G6 (VIN Z) Service Manual | Document ID: 1492608
RPO Code List
RPO
Description
AG1
Adjuster FRT ST Power, Multidirectional, Driver
AK5
Restraint System Seat, Inflatable, Driver and Passenger
AP3
Lock Control, Entry Remote, Keyless Entry, Start
AP9
Net Convenience
ASN
Adjuster FRT ST Manual, 2 Way, Power Vertical, Driver
AU0
Lock Control, Entry Remote Entry
AY0
Restraint System Seat, Inflatable, Driver & Passenger, FRT & Side, Roof Side
A51
Seat FRT & Side, Roof Side
CF5
Roof Sun, Glass, Sliding Electric
C3Y
Roof Sun, Glass, Sliding, Panels, Electric
C60
HVAC System Air Conditioner FRT, Manual Controls
C68
HVAC System Air Conditioner FRT, Automatic, Electronic Controls
DK6
Console Roof Interior
D49
Mirror O/S LH & RH, Remote Control, Electric, Manual Fold
E90
Pocket Front Seat Back, Driver
E91
Pocket Front Seat Back, Passenger
FE0
Suspension System FRT & RR, Active
FE2
Suspension System Ride, Handling
FE9
Certification Emission Federal
FR9
Ratio Transaxle Final Drive 3.29
FX2
Ratio Transaxle Final Drive 3.91
F83
Ratio Transaxle Final Drive 3.05
IBB
Trim Interior Design (BB)
IBC
Trim Interior Design (C) (97)
IB2
Trim Interior Design (B2) (99)
JA7
Handle Park Brake Release, Leather
JF4
Pedals Adjustable, Power
JL9
Brake System Power, FRT & RR DISC, Antilock, FRT & RR Wheel
J65
KA1
Heater Seat, FRT
KO5
Heater Engine Block
K34
Cruise Control Automatic, Electronic
K64
Generator 115 AMP
LE5
Engine Gas, 4 Cyl, 2.4L, MFI, ALUM, DOHC, HO, ECOTEC
LX9
Engine Gas, 6 Cyl, 3.5L, SFI, V6, GM
MN5
Transmission Automatic 4 Speed, HMD, 4T45-E
MX0
Merchandised Transmission, Automatic Provisions O/D
NE1
Certification Emission California
NR0
Steering Wheel Leather, 4 Spokes
NT7
Emission System Federal, Tier 2
NU2
Emission System California, ULEV2
NW7
Traction Control Powertrain Management Only
NW9
Traction Control-Electronic (TCS)
N46
Steering Wheel 4 Spokes
PFE
Wheel 17 x 7, Aluminum
PFF
Wheel 17 x 7, Aluminum, Painted
QB5
Wheel 16 x 6.5, Steel
QD1
Wheel 16 x 6.5, Aluminum, Styled
QPE
Tire All P215/60R16/N BL R/PE ST TL AL3
QWN
Tire All P225/50R17-93V BW R/PE ST TL AL3
T43
Spoiler RR
UA6
Theft Deterrent System
UC2
Speedometer INST, KILO & Miles, KILO Odometer, Positive BIAS
UC6
Radio AM/FM Stereo, SEEK/SCAN, RDS, Multiple Compact DISC, AUTO TONE CONTROL, CLOCK, ETR
UE1
Communication System Vehicle, G.P.S. 1
UJ6
Indicator Low Tire Pressure
UNO
Radio AM/FM Stereo, SEEK/SCAN, CD, AUTO TONE, CLOCK, ETR
UPO
Radio AM/FM Stereo, SEEK/SCAN, AUTO REV Music Search Cass, CD, RDS, AUTO TONE , CLOCK, ETR
UZ6
Speaker System 6, Premium
U1C
Radio AM/FM Stereo, SEEK/SCAN, CD, CLOCK, ETR
U2K
Digital Audio System S-Band
U2L
Digital Audio System L-Band
U65
Speaker System 7, Premium
U77
Antenna RR Window, Radio
VY7
Knob Transmission Control Lever, Leather
V73
Vehicle Statement USA/Canada
W1Y
Control Steering Wheel, Radio, Redundant Controls
Z49
Export Canadian Modifications, , Mandatory Base Equipment
14B
Trim Combination Cloth, Gray (B) (97)
14C
Trim Combination Cloth, Gray (C)
141
Interior Trim Gray
142
Trim Combination Leather, Gray (2) (97)
16U
Primary Color Exterior, Bright White (96)
© 2012 General Motors Corporation. All rights reserved.
Well RKE is to select you want to arm the security system with the remote, and passive means the car should lock/arm itself after you leave the vehicle for a certain amount of time. I may be wrong, The manual isn't very clear on that. Or at least I couldn't find it.
I have an '09 And that option doesn't even exist for me....
Discussion Starter #16
hope so lol because i purchased the radio. the metra 99-3303 and the dash install kit and antenna adapter lol
Thank you all for your help.
Jamie
Believe me it will, I have a Alpine IVA-W505 that has a flip down face and I have had no issues.
Make sure when you are installing it you space the headunit evenly in the dashkit, because if there is not enough space at the top the faceplate can bind, causing it not to open. The closer to the bottom you can get it the better.
1 - 17 of 17 Posts
