It seems like I need new wheel bearings. Is there a manufacturer that members can recommend to use? 2008 G6 GT sedan.
As Zenish says, I would look at the genuine replacements for this. I believe you need to buy the wheel hub assembly as the bearings are not replaceable on their own. ABS or non ABS. I tried an after market unit and had to replace it again in 6 months. Not an economical option to my mind. Also I would suggest you replace both. I tried to identify the "noisy" one and the replacement simply allowed me to hear that the other side was also on it's way out. I often find RockAuto.com a good place to get what you need. Good luck with the fix
