Hi I just bought an 07 convertible and theres a shake at 65mph.. with the top down it's so much worse..should I just rebalance the tires or should I be looking at something else? It has only 70k miles. Thanks!
Recently had a similar issue with my G6. Tires are out of balance (getting them fixed up this week) and causing the majority of the shaking.
A lot of shaking can also be indicative of bad/worn out struts (which can help dampen the shaking) and bad tie-rod ends. Replacing both made a significant difference without even balancing the tires.
I would start with the tire balancing though.
