been a mechanic for years, always look around and join a forum about the vehicles I'm working on, searching for solutions and suggestions. working on an 07 G6 GTP with the 3.6 with multiple crank correlation codes, gonna look around to see if ya'll got any answers!! :beer::beer:
good luck.....but while your here....i belive my right steering shaft is loose. Is that possiable? I get a wobble at times. I know my bearing plates are going bad, could that also be the issue aswell?
Thanks
are you talking about a tie rod or a cv shaft? both can cause a wobble but most likely the tie rod is the culprit. even a bad tire will cause a wobble. the bearings will make a growling noise that will come and go if you move the steering wheel a little to the left or right as your driving, unless you've let it go for so long that it's toast it'll make noise all the time. cv shaft noise will usally be while your turning under power, it'll make a pop, pop, pop noise.
