Hi,
My name is Bill, I am from East Perersburg Pa.
I have 2 codes currently on our 2006 G6.
They are:
P0303 Cylinder 3 miss
P1174 Fuel trim cylinder balance bank 1.
Is this something I can fix myself or should I take it to the garge.
Old far...er...tinkerer..
Hi,
They are:
The cause and effect needs to be determined first. I suspect the miss on cylinder three is causing a rich condition in the exhaust resulting in the fuel trim message. But I also wonder if could be the other way around, if a leaky injector could be causing a rich condition and also causing the miss.
I suspect the former. What motor is in the car? Have you inspected under the hood? A bad plug wire could be causing the miss. Or maybe the plug is bad. If the wire and plug are good, I'd probably try a new coil pack. After that, I need more expertise :)
Doug
Doug
We dropped it off at the repair shop last night. My wife said she had no stearing and it stalled when she got to the shop. It seems to be the alternator. Is it possible the codes are because of the alternator is not putting out the correct voltage.
How many miles on it? Plugs are good to 100k.
Youd be surprised what a new set of iridium plugs and wires will do.
The newer cars have electric power steering (rather than hydraulic). So if the electrical system can't produce enough power, the steering cold be affected.
But if the alternator is so bad as to cause that issue, I'd expect a dead battery - ie, a no-start condition.
As for the other problems, I'm sure a low voltage condition can cause things such as misfires and stalling. But again I'd expect a dead battery before I got those problems. That said, if the voltage regulator (inside the alternator) had gone intermittent, it might could cause some of these other issues without causing a dead battery.
I hope the new alternator fixes everything. Let us know if it does, or if you still have misfires and stalling afterward.
Doug
Hi,
I am Aaron from Chicago Illinois. I drive a 2008 Pontiac G6 GT. I am having problems with the speaker being distorted at low volume.
