You got #1 answered.
2) I have a monsoon system - all stock - howannoying is it to put an ipod hook up in this thing.
3) Thinking about tinting the windows, can anyone suggest a good amount, I feel like a little tint will go a long way especially with the tiny windows in the back.
4) Wondering about removing the badges on the back, but don't want to jack my paint or anything, would like to hear from someone who has done this successfully.
2) Essentially there are three options.
A) If you want to use an AUX input to the stereo, you could get a newer model stereo and swap it for the one in your vehicle. You will then have to go to the stealership to have it unlocked to work with your vehicle. All in cost will probably be around $150 if you swap it yourself.
B) There was someone on this or one of the other boards that was doing mods to your stereo to add a front panel AUX IN jack. I think it would be about $75 all in. The disadvantage is having a hole in your dash for several days because you have to ship your stereo off to this guy and wait for him to get it back to you.
C) For about $150 all in (if you do the installation work yourself) there are several different outfits that will sell you a plug-in interface that connects to the bottom of your iPod/Phone and allows you to control it through the deck.
Options B and C require that your head unit be Satellite Radio ready (even if you don't have XM).
3) I went 50% front and 35% rear on mine, but I already had 70% windows from the factory. I probably could have gone darker, but I didn't want to go for the limo look and overall I am pleased.
4) I used a hair dryer and debadged mine when it was about 62 and raining (I was under the garage door out of the direct rain). I used dental floss because I don't have any lighter weight monofilament. Heat the badges up for 3 - 5 minutes (bigger ones need more time of course) and slide the line/floss behind the badge. I found it fastest to wrap the floss completely around the badge (making a lasso/garrote) and puled on the end until the badge came off. For some of them you will have to keep applying heat. It would go a lot faster with two people doing it, one keeping the heat on.
DON'T use a heat gun as it is really easy to go from hot paint to bubbled paint. A hair dryer won't get your paint hot enough to bubble, but it may soften it temporarily so be careful with anything that may scratch or gouge the finish.
When the badges pop off, there will be adhesive remaining on the car. Keep warming this up, and remove the thicker portions of it by rolling it with your fingers (wear heavy gloves to avoid heat blisters). When there's just thin patches of adhesive left, you can remove it using Goo Gone or similar.
Oh, and the last word of advice/warning on this, if you plan to remove the dart (Pontiac logo), it is a real mother****er as it soaks up and dissipates a lot of the heat. You are going to want to pry it off as soon as one end starts to come loose, probably the bottom point. Be careful with this. Remember the warning above about softened paint? If you pry too much, the upper points in the dart will sink into your paint (unfortunately I know this). You can slide a piece of thin cardboard (cut up a cereal box and use two layers) behind the upper points of the dart to help protect your paint if you pry.
I thought about writing a how-to just about when the last badge was coming off, too late to get any decent pictures.
Oh, and WELCOME TO THE FORUMS!
~ MattInSoCal
