Thanks for the membership.I recently purchaced a 2007 Pontiac G6. So far I've had to change exhaust flex pipe was leaking. Replaced lower control arm on front passenger side. There's 2 rubber bushings and a ball joint on the control arm. The rubber bushing towards rear of car, was wore out, cause the front wheel to have movement forwards and backwards. Door key lock was broke inside door latch actuator. Had to replace it. Still haveing electrical issues with anti-theft system. Horn goes off when I unlock door with key and previous owner lost key fob.
