Woke up this morning and went to start the car and turn on the heat and defrost with no luck turned the fan speed switch to 1 expecting the climate control lights top come on with no such luck then attempted to turn on the rear window defrost and had no luck again check all fuses and found no open fuses... need help 2005 g6 v6 3.5l
I think I am having the same problem as you did.. none of my controls work for the ac/heater/defroster.. it won't turn on at all. Did you ever find a solution for this??
