2007 pontiac g6 3.5 v6
Sometimes my 2007 pontiac g6 wont crank, just click. I wiggle the wires in front of the motor and it will spark then crank but someone has to be trying to crank it while I wiggle the wires at the same time. And there are times when i can turn the key really fast to crank it a few times and it cranks. Please help
While electrical problems aren't my strong point I suggest you try the following . The wires that you shake need to be tested for continuity . Grab a multimeter and back probe each wire , I think you can then isolate a wire that is cut or broken or a loose connector .
