1 - 1 of 1 Posts
Hello all. I recently had my steering rack and pinion assembly replaced on my 2005 G6. Before it took it to a buddy mechanic of mine the cruise control and horn worked fine but when it came back these things did not work anymore. He swears he doesn't know what happened and can't figure out what the problem might be but he says he things it's a faulty clock spring.
As a side note the horn works when the alarm is engaged or activated. Is there a harness on the steering column that I can check or some other part of the car I can check to see if something came loose?
Thanks in advanced for the help.
1 - 1 of 1 Posts
