have a rattle--sounds like a belt buckle-happens going over rough roads or expansion joints--not seat belts-getting annoying--any answers?
If coupe could possibly be the third brake light cover, seen alot of complaints about those. If not I honestly don't know what it could be.
I occasionally get one too. It sounds like it's coming from the back right of the car. I can't figure out what it is though.
rattle-found it
Under pass. door--black moulding connecting to body - i saw a rubber piece-very thin hanging--i sprayed lithium grease in that area--no more rattle--going to put foam stuffed in the places between the plastic and body etc--should make ir permanent
Check your trunk hinges -- with the lid closed, push down on either side of the back edge of the trunk lid (closest to the bumper), in the corners (by the tail lights)... such that you are wiggling/rocking the lid from side to side. See if that creates something similar to the noise you hear inside. If so, you need new trunk hinges. They ordered some for mine and that stopped the rattle noise I was getting over bumps and coming and out of the driveway.
