1 - 1 of 1 Posts
Oil leak on right side of engine. Had crankshaft seal replaced, but did not fix the leak. I believe the leak may be the timing cover gasket? Book tells me to remove right side sub frame bolts, loosen left side and lower sub frame???? Do I really need to do that to replace the timing cover gasket? Can the timing cover gasket be replaced, without screwing with the sub frame? Thanks
1 - 1 of 1 Posts
