You may want to take that to the dealer.
If you bought it used, the odometer may have been tampered with. Don't take it to the dealer you bought it from (if you in fact did buy it from a dealer.)
If someone had to replace the instrument cluster for what ever reason. The season odometer value may be stored in the IPC, the Driver Information Center (DIC), or the Integrated Body Control Module (IBCM), also commonly called a Body Control Module (BCM) cluster for whatever reson they would have to get the info.
There is a TSB for retrieving this info and that may very well tell you if it was tampered with.
The TSB is Bulletin No.: 07-08-49-020C
Date: April 23, 2009
