I'm a little confused on what you're asking for question #1, might want to post pics. All I had to do was splice the black and red from the ballast into the stocking wiring. As far as the fuse goes, if you splice into the factory wiring then it will be using the factory fuse on that power wire.First of all I'm completely confused on how to install the HID's. I tried following that stupid little instruction manual but that thing is junk. I have a few question I can't seem to figure out.
1) where do you put the red and black connectors that go inside of the projector right by the bulb itself. It has 2 male connectors but on the headlight itself there are only male connectors on there. Unless this is a sword fight the two don't go together.
2) After the spacers are installed how do you get the clip to hold the bulb down? It doesn't come even close fitting with the spacers.
3) What should I be hooking the ballast to? It says hook it up to a 20W fuse but does that mean i have to run long wires from the pass side to the fuse box? In hindsight I would have never got the HID's unless I'm just completely retarded on this install. Any help would be greatly appreciated!
